Old 1-Jul-2012, 9:26 PM   #8
Electron
ALL questions and answers about broadcast tv reception and More.
Moving forward with improving reception.
Aim the VHF antenna at about 47 degree magnetic compass.
Aim the UHF antenna at about 135 degree magnetic compass.
With the antennas aimed at those directions , hopefully all of the Tv stations/channels (except WHPX-TV 26 ION) will be received.
WVIT-DT Real channel 35 NBC and New York Non Stop
WCCT-TV Real channel 20 CW and This Tv
WFSB Real channel 33 CBS and Eye Witness News
WTIC-TV Real channel 31 FOX and Antenna Tv
WTNH-DT Real channel 10 ABC and Bounce
WEDH-DT Real channel 45 PBS
WSAH-DT Real channel 42 Me-Tv and RTV
WUVN-DT Real channel 46 Univision and Telefutura
WWLP-DT Real channel 11 NBC and COOL Tv
WCTX-DT Real channel 39 MyNetwork and COOL Tv
The reason hopefully , is the Tv stations are widely spaced around the compass. Tv antennas receive the best when the Tv antenna is aimed at the Tv transmitting antenna.
The further off to the side at an angle the Tv transmitting antenna is to the receiving antenna the less signal will be received.
Aim the UHF antenna inbetween the UHF stations that are to the East and South , inbetween is about 135 degree magnetic compass.
Aim the VHF antenna at about 47 degree magnetic compass to receive the weak signal strength WWLP and hopefully the stronger signal strength WTNH at 173 degree will be received through the back angle of the VHF antenna.
For a A LOT STRONGER Tv Signals the antennas must be moved from the attic , must be mounted above the roof.
http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal buy typing the word ronard in the solidsignal search box. http://www.solidsignal.com
If this set up does not get all the channels (except WHPX-TV 26 ION) then some Tv antenna changes will be required.
