Old 7-Sep-2010, 2:29 AM   #2
Dave Loudin
Click on any of the stations at the top of the list in your report. You'll see that you are in the shadow of a hill between you and Mt. Wilson where 98% of the LA TV transmitters are. You are almost certainly going to need to mount an antenna on the roof to get anything. Before recommending size, rerun your report via the maps option. Be sure the receive marker is pointing at your exact location (drag it as needed), then play with different values of antenna height, starting with the height of your roof. If the NM values suddenly jump, then you will be able to use a smaller antenna.
