Old 1-Jul-2012, 3:15 AM   #40
You're probably OK. The UVSJ is the least likely to have a problem with that. Some UVSJs will not pass DC or 60 Hz AC. If that's the case here, no current was flowing from the power supply to cause any damage. If the UHF port on the UVSJ presents a DC/Low-Freq-AC short, the power supply may not like being connect to a short circuit termination. Some power supplies have a non-serviceable fuse inside. Do you have a Volt-Ohm meter to check the power supply for output voltage? If not, just hook it up correctly and see if signal passes through the amplifier.
