I wasn't expecting much. My former rotor Alliance Tenarotor was 50 years old!
I have a yagi antenna that was state of the art then on the Old Alliance. I haven't seen the control for it for about 30 years. The reason I didn't connect the small and medium sized loops was looking at the diagrams and the box. Am I correct that the medium loop is the only active one? Should it be joined at center? Should all others not be joined at center? Maybe the active element shouldn't be joined either.
I have just looked around the net a very little. I'm guessing that the loop designs are called dipoles. I don't know what an antenna with many of these should be called.
I'll have to do some more searching.
THANKS FOR YOUR RESPONSE
