ALL questions and answers about broadcast tv reception and More.
You see you are receiving channel 7 with out even trying and the signal for KABC 7 is a weak minus -1.5 NM(dB).
This low signal strength weak reception discovery , then also spills over in to the idea of weak reception of , VHF low band channels 2 thru 6 , and UHF band channels 14 thru 51.
Yes weak signals can be received.
I did my best to get you to install a antenna that receive ALL the channels
As for aiming the antenna up a little , bend the mast a little.
Reason: spelling corrections.
