The Silver Sensor you have is a UHF-only antenna, so it won't work very well with WJLA and WUSA, which are VHF stations. Terk has an antenna modeled after the Silver Sensor that includes integrated rabbit ears for.VHF. If you wanted to get one of those, be sure it's the unamplified version, the HDTVi. However, you might try the most basic indoor antenna of all, first - the rabbit ears/loop combination. You shouldn't have to spend over 15 dollars for one. Be very sure that it has no amplifier, no matter how tempting.
