I presume WXMI, real CH-19 is the signal you're seeing from Grand Rapids. If that's the case, once the atmospheric conditions revert to a more normal state you'll not be able to receive that signal.
But you're right, day to day some signal may be bouncing off layers of the atmosphere, causing interference to the local WGN signal. In a perfect world, you'd have access to the roof or your own tower and you could use a high gain directional antenna that would ensure a stable signal from WGN.
