I'm truly sorry that you're frustrated, but I'm not at all convinced that your circumstance proves or even suggests a deficiency on the part the information this service has provided.
The
TV Fool Signal Analysis FAQ addresses the issues you raise. Along with quite a bit of other helpful information, the following disclaimer is included in-part because of situations such as yours.
Please understand that this is a simulation and can only be treated as a rough approximation. Reception at your location is affected by many factors such as multipath, antenna gain, receiver sensitivity, buildings, and trees - which are not taken into account. Your mileage may vary.
So, no, it did not say,
that an indoor set top antenna is sufficient
Given that TV Fool has no way of knowing what trees buildings or RF interference sources are present, it's reasonable to expect the user to make allowance for the additional factors unknown to the free service provider.
So, it's up to you... you can choose to try what's suggested or you can choose not to. I can assure you, your anger and frustration will do nothing to overcome the challenge.
