Old 29-Jun-2012, 2:28 AM   #23
eric12341
So it's entirely possible that TV Fool has provided you with a signal prediction that is reasonably accurate and the obstructed mounting location close to the ground leaves you with little useable signal.
If you can afford about $30 worth of hardware from Home Depot, you can make a guyed mast 10' or 20' high. Their fence top rail makes an adequate mast. Combine that with some 1/4" Dacron rope for guys and you can at least 'test' the reception at 10' or 20' AGL.
It's not accurate at all, it said that an indoor set top antenna is sufficient to receive the stations I want. That's far from the truth because the indoor set top antenna I bought barely worked ,if at all till I sat it outside. It then worked till about March or April when I decided to buy the ANT751. I threw the set top onto the roof in rage thinking it would work better up there but the cable came loose before I got to hook it up.
eric12341 is offline   Reply With Quote
