Old 7-Sep-2010, 12:13 AM   #2
John Candle
Tv Reception
Your location is close to the transmitters , the signals are VERY STRONG , NO ANTENNA AMPLIFIER is needed. A Non Amplified indoor antenna should be Ok . http://forum.tvfool.com/showthread.php?t=233 . A simple roof top antenna will be fine. If the house has the standard flat composition shingles , a strong and sturdy mount to use is a tripod mount. Or a eve mount at the peak of the roof works well. This antenna , Winegard HD7080P is a Heavy Duty antenna so as to last a long time out side. Do Not connect a amplifier , the signals are very strong and easly overload a amplifier. http://www.solidsignal.com
