ALL questions and answers about broadcast tv reception and More.
I quote from elsewhere on this question askers post.
" It is unlikily that the transformer is the problem "
The word 'unlikily' is likely not a typo because it is followed up with ,
"but the test suggested by Electron makes sense, as it complety eliminates that possibilty of transmission line problems , "
Is it just me or is there mud stirring often going on when I print something and say something.
Like I said just because the matching transformer looks good does not mean that the transformer is good.
Self fusing rubber tape will stop water leaks. The self fusing rubber tape works so well that the only way to get it off is cut it off of what it is applied to.
Self fusing rubber tape works so well that it is often better to cut off the part that is applied to and start over with new.
Use No boot , when using self fusing tape.
And sometimes a matching transformer is bad just because it is bad manufacturing internal connections damage.
