The EZ HD is all of the antenna you will ever need for stations 4.5 miles away.
Did you try the subsitute coax/matching transformer yet? I have found some of the new matching transformers to leak badly. The worst one is the Philmore. It leaks even with the boot properly installed. Other Chinese models will too. The problem is so bad that I have been using a product called Cold Shrink to wrap all the way from the coax, over the connector and to the end of the caseing, then siliconing the input end.
