If I am the only one on planet earth that is stating the situation of how some others go about dealing with channels 2 thru 6. The disclaimers , it is to far away , it is too weak , it is too much effort , give up before you start. And etc. .
Then so be it.
Also , the low power Tv stations channels 2 thru 6 , very often change programing. And often change from less desirable type of programing to more desireable type of programing and visa a versa.
And low power TV stations are not limited to the VHF low band of channels 2 thru 6.
Low power Tv stations are also , VHF high band 7 thru 13 and UHF band 14 thru 51.
Any Tv channel can and is a low power station.
