Of the low VHF that you could receive from your location, channel 6 will not require the large all channel antenna. The other low V channel 2 is a distant low power station and would most likly not be received. You could use a smaller RCA ANT751 on the satellite mount, provided that it clears your roof and any other obstructions. This should receive the same amount of channels as the larger Winegard antenna.
