ALL questions and answers about broadcast tv reception and More.
Here are a Truth statements.
If the matching transformer and coax has been damaged by water , putting more water on the matching transformer and coax will not prove
Just because the matching transformer and coax looks ok does NOT mean that the matching transformer and coax is ok.
A way to prove out the reception is to connect a Known to be good matching transformer and a Known to be good coax to the matching transformer and run the coax Direct to the Tv , no splitters , no amplifier , no nothing.
It is the , antenna , a Known to be good matching transformer , Known to be good coax , direct to the Tv.
And just because the tuner in the Tv is supposed to be ok does not mean that the tuner in the Tv is ok.
