Old 6-Sep-2010, 9:30 PM   #3
narkspud
Sheesh, what a grouch
KLAU-LP (analog 45) has been off for several months now, and I presume they're gone for good, although you never know with these guys.
On a related note, no one in the LA AVS Forum topic has seen any trace of KLAU-LD on 53. I should be getting them here in Tustin if they're on the air with anything resembling full power. I'm not.
My "current" plot is showing two channel 23s, at similar strengths and from the same direction - KSGA-LP and KSMV-LD. I'm pretty sure KSMV is the one I'm picking up, since it's identified as such and maps to 31. The signal is quite solid, so I would assume KSGA isn't on the air.
I would also assume KNET-CA's digital 25 isn't on yet, since their analog is still occupying that channel.
One more update ... KTAV-LP (real ch. 46) maps to 35.
Everything else, AFAICT, is correct.
narkspud is offline   Reply With Quote
