I gather the CA7078 has been in place for several years at this point? A small amount of corrosion, particularly at the connection between the antenna phasing lines and the matching transformer could produce low signal output, skewed pattern & intermittent symptoms affected by changes in temperature or humidity.
@Electron mentioned the Winegard HD7698P earlier, and in your situation it makes sense to consider using one. I honestly believe you should be able to gather enough signal out of the air... with no amplifier at all.
Before you do that though, a less expensive upgrade can be tried. Add an FM trap. You can find them at Radio Shack, Cat. No. 15-024. You may find it helps with real CH 7 and possibly others. It needs to install between the antenna and the preamp. (The second harmonic of KCRW-FM, 89.9MHz lands in the top end of real CH-7's bandwidth. {89.9 * 2 = 179.8}... Real CH-7 is 174 to 180 MHz.) If you replace the antenna, the addition of the FM trap is still prudent.
Reason: Commentary re. KCRW-FM
