Thanks for the replies, Electron and GroundUrMast. I hadnt thought of the transformer, though it does have a pretty tight fitting boot on it. I will double check that and re-route the coax. Probably go up when it is dry and spray water on the transformer and see if this dupes the problem.
Assuming the transformer is not the problem, I will give the driveway location a try. The only concern I have about the driveway location is that the antenna will be perhaps 4 or 5' above the roof of my van parked next to it - the van will be positioned in the line to the transmitters. Would this likely cause a problem?
Thanks again.
