Old 26-Jun-2012, 1:08 AM   #13
signals unlimited
You need to use a two set splitter. If you install the splitter outside and between the amplifier and the power supply, you need a splitter with a DC pass port. Connect the line to your cabin to the port that passes DC and place the power inserter in your cabin. The other port can run to the other cabin and connect directly to the other DTV or converter box.
