If you use the AP8275 suggested by @Electron or the competing Antennas Direct PA-18, no additional amplifier should be needed. Simply select a passive splitter with the number of needed ports. For example, if you need to feed signal to 3 TV's, select a 3-way splitter. To drive 4 TV's then use a 4-way splitter.
As a side note, 3-way splitters are usually unique in that one of the output ports will have half the loss of the others. The lower loss port is best used for driving the longest piece of coax.
