Old 25-Jun-2012, 10:30 PM   #21
BikingBrian
I might end up with a situation in which the VHF and UHF antennas are on separate masts, probably about ten feet apart. In that case, what is best for the preamp? Combine the antennas into a UVSJ before going to a single preamp? Or separate preamps with two coax lines into the house? If I go the latter route, can I use a UVSJ after the power inserters in order to avoid an A/B switch?
BikingBrian is offline   Reply With Quote
