ALL questions and answers about broadcast tv reception and More.
If you will like to try reception without the preamp.
Simply unpluging the preamp will shut the preamp off and the preamp will become a attenuator.
ALL parts of the preamp must be disconnected if you will like to try reception without the preamp , the outside part , the inside parts.
ALL parts.
Yes the sun can blast the signal and reduce or bloc the signal.
Also check -> ALL <- connections.
Has water entered any of the outside connections??
The starting aim direction of the antenna is the , starting aim direction , the antenna can be turned to find a aim direction that is best signal for the tv stations/channels you will like to receive.
