It appears that your report is based on the default height of 10'. If that is the only mounting height available, we can make recommendations based on that information. However, if you can mount higher, a TV Fool report based on the available height would be helpful.
I suspect you're surrounded by trees. If that's true, what type and how tall? Can you consider a mast or tower tall enough to place the antenna above tree-top level?
