I doubt you could use it for cable if the RV park is using digital cable. Digital cable uses QAM which satellite STBs doesn't support. Might work with analog cable.
Also this site is for discussion of OVER THE AIR reception not cable or satellite. if you would like to learn about how to get channels via antenna this is the place.
