The C5 is a very good choice as a high-VHF solution in your case, provided it's not blocked by trees. If you're shooting through trees, the more directional Y10713 would provide a margin of protection from the foliage induced interference.
Either the DB4e or the HD9095P will do fine receiving WTOM and WCML... again, provided the trees are not a significant issue. If they are, the HD9095P is a more directional antenna and would therefor be the better choice. (An Antennas Direct 91XG would be a competing product to the HD9095P.)
So essentially, the relatively weak signal from WCML indicates the need to use an outdoor mounted antenna.
