Thread: Chicago
Old 5-Sep-2010, 2:27 PM   #5
Tommie
I looked at the Winegard website and they mention an antenna Winegard FV-HD30 FreeVision. It looks easy to use but I'm worried it might not get channel 2 for me. Please can you explain the difference between these two Winegard antennas for me? I did find the 7694P at a local electronics store for $50.
I'm thinking of putting it in the attic myself now. I have cable running up there from a main center located in the basement. The center now has a dish network attached to it. Should I run the cable from the antenna to the basement ( where it is then already routed back to the attic and then down to two rooms for TVs) or attach the existing cables in the attic to the antenna?
Tommie
Tommie is offline   Reply With Quote
