The stations located at 89 and 297 degrees magnetic could be received from that location.
The concrete and steel may make it a litle difficult. If there are windows or if he is located on the East or Northwest side of the building it will be easier to make this work.
Can you take in a rabbit ear antenna? If not I will tell you how to build something from a metal coat hanger or foil on cardboard.
