Not sure that this is going to work, the blowtorch will likely melt the plastic holding the metal to the antenna.
I did do a google and was concerned about the above problem hence I was thinking more about soldering it with a soldering iron.
I was also thinking about putting it up as is but did not know if a fracture on one side of an element was going to cause profound performance problems or if it would be okay.
Mike
