Old 22-Jun-2012, 6:30 PM   #3
The C4 would be expected to receive all the Philly stations except channels 6 & 12. Those two stations require a VHF antenna. A modest channel 2-13 unit, perhaps an AntennaCraft CS600 combined using our EU385CF combiner should work. If Fox isn't coming in with the C4, you'll likely need to move the antenna elsewhere and try again.
The C2v *might* work okay since WPVI has a signal that for channel 6 is pretty hot, but you'd do best with the correct antenna. The boss tested it last winter when he was in the area and said it picked up WPVI well enough.
The suggested Leviton and Axis devices are not useful for this project.
