Old 21-Jun-2012, 8:43 PM   #5
Hod
Wink Reception limited
Hi, thanks for your feedback.
Since the amplifier might be causing a problem with the reception, I turned down the gain on the amplifier. This caused the TV to have no picture to a worse picture.
I had initially tried to put the antenna near the window while changing the compass orientation of the antenna. I actually received no OTA signal with the antenna near the window.
Do y'all suggest I try another type of antenna, an unamplified one. Is there a better design and build that would give me more success? Can you suggest an antenna manufacturer and model?
Thanks so much for the guidance y'all provide. I really appreciate y'all's help.
I apologize if I have asked questions that you have already answered.
Best,
"Hod"
Hod is offline   Reply With Quote
