Old 21-Jun-2012, 8:39 PM   #7
Electron
ALL questions and answers about Broadcast Tv reception and More.
The Y10713 is a antenna that is desinged to receive VHF high band channels 7 thru 13. Not VHF low band channels 2 thru 6 or UHF band channels 14 thru 51.
The Mount Wilson area Tv transmitters at about 230 degree magnetic compass that are receivable at -> Your <- location are in a process of changing the channels that are being transmitted.
The end result will most likely be that there will be VHF low band channels 2 thru 6 , VHF high band channels 7 thru 13 , UHF band channels 14 thru 51.
The way to cover what ever channel is changed to and not changed to is to install a HD7084P antenna that receives All the channels , VHF low band channels 2 thru 6 , VHF high band 7 thru 13 , UHF band channels.
