I'm coming up for air again, Over the air that is! And I am reporting back my attic adventures.I found the antenna to be in pretty good shape as far as nothing broken or even bent. I am still getting around to trying to aim it better. The one I have, have as the longest most rear elements a four foot tube off of each side of the boom. Then going forward the next elements are three feet and then two feet and then a foot. I think it may be pointed too much to the south. But I'll get back to that issue. I just wanted to check in with this info and see if this size description met with any comments. Even where it is there would seem to be more much more room to grow. I gues I should measure before I ask but have you all any suggestions for a good next size up? I'm still willing to ultimately end up above the roof of course but I just want to make this as hard as I can until then.
herplace
