Old 21-Jun-2012, 7:50 AM   #5
BikingBrian
Originally Posted by Electron View Post
For reception of more Tv stations and channels install a Winegard HD7084P All channel antenna with a Winegard AP8700 preamp above the roof aimed at about 230 degree magnetic compass.
That's an interesting idea. I can live without the UHF channels at 230 degrees, so what about just a high band VHF antenna pointed in that direction to pick up the four channels in that range? Any antenna recommendations for that? Could I then use a VHF/UHF combiner, run one coax, and get by without the preamp and A/B switch?
By the way, I'll only be using two TVs on this setup. Actually, this is a vacation home, so we could even get by with only one TV.
BikingBrian is offline   Reply With Quote
