Old 21-Jun-2012, 1:29 AM   #5
tiredofpayingfortv
Thanks for the replies! I forgot to tell you during the first post that I am using a rotor on my old antenna. Electron, would you still make the same suggestions? I played with the signal strength meter on my TV tonight and found that the signal strength for one channel can be inproved by moving the antenna a few degrees one way or the other but another channel in the same physical direction may need to move the other direction a few degrees which would suggest that you almost need the rotor for adjusting to channel that are in the same listed direction.
tiredofpayingfortv
tiredofpayingfortv is offline   Reply With Quote
