Use a Winegard 9095P and a Channel Master 7777 preamplifier. Aim to 171 degrees magnetic.
Mount as high as practical, clear of any trees or buildings.
This antenna is highly directional and may not receive the Canadian stations. To receive the Canadian stations use an Antenna Direct CS2 aimed toward the desired stations. Use a seperate coax, and an A/B switch to go between locations. You can not combind these systems into one coax.
