Old 20-Jun-2012, 5:59 PM   #1
Fauvel
OTA lanaudiere signal strength reduced
Hello,
My Father is the Lanaudiere region. I set him up for DTV last year but a few weeks
back the signal was apparently reduced in strength.
This is close to Rawdon, ST Alphonse Rodriguez, Chertsey
Is it possible signal strength has been reduced or the antenna relocated?
I tried 2 converters that worked there previously. I tried 2 antenna amplifiers.
One decoder shows weak signal for stations i had previously. I loose signal
if i disconnect the amplifier or the antenna. A small antenna instead of the roof
one gives no signal either. This indicate amplifier and antenna are still functionnal.
It could be a bad connection somewhere.
My father will not pay for pay tv at his chalet.
Sylvain
Fauvel is offline   Reply With Quote
