Old 20-Jun-2012, 4:59 PM   #5
You should be able to pick up the Newport/Lincoln City translators with the proper antenna and pre-amp. Rooftop is strongly recommended.
There is some ambiguity regarding what channels are in use in that area. Translator K05KY has been licensed to operate on VHF channel 5 in analog and holds a construction permit to build a digital UHF 27 replacement. I can find no evidence that either facility is operating. Should they be operating, they should be re-broadcasting KWVT-LD. KDLN-LP (LD) is operated by the same owner and would likely be the same fare. They're supposed to go from VHF-4 to UHF-24.
You do only have a handful of available stations at your disposal with several (perhaps) to come. Eventually, all will be UHF making a "long-range" UHF antenna with a pre-amp the suggested solution.
