Use a Winegard HD7698P and a Channel Master 9521A rotor. This will receive WSET 13 and all of the UHF and High VHF stations from Roanoke. Dont use a Pre-amplifier. If you are connecting more than 3 sets you should consider using a distribution amplifier.
Test run the rotor on the ground using a short three conductor cable. Leave it at the counter clockwise end of rotation. Install with the antenna pointed to 0 degrees magnetic. you will be able to use the 360 degree display to locate many channels.
