Old 15-Jan-2010, 3:15 PM   #5
jbrams
That's not going to work. The C-4 is a UHF only antenna. You have three VHF stations from SF.
Consider the Winegard HD7698P with an AP-8700 preamp.
Sorry I'm so new at this, but which three are from SF?
I see
KGO-TV (7.1)
KNTV-TV (11.1)
KTVJ-LP (36.1)
Is that right?
If so, bummer - 7 and 11 are major net work channels (ABC and NBC) that would be a priority to receive. Channel 36.1 isn't a priority but it'd be nice
So it seems I will new a UHF and VHF antenna. However, I'd like to avoid one as large as the HD7698P is possible.
Would the Channel Master 4228HD be sufficient? Would it make a difference if it had a pre-amp?
Any alternatives with VHF and UHF that are smaller than the HD7689P that would be adequate? The VHF channels at issue seem like they are not going to take too much to pick up if that helps.
Thanks again!
jbrams is offline   Reply With Quote
