rural va antenna choices
I'm new here but after read some of the posts it sounds like some of you know more about my situation than I could ever learn so I'm looking for advice!
I have an old antenna mounted on my chimney 20-25 ft up and a booster of some sort with one part on the antenna and one part at the tv, all second hand so I don't know what it is but the antenna is pretty large and resembles the CM3671 or cm3679 and probably running about 35-45 ft of coax. On a good day I receive many more channels than antenna web says I could get and all the major networks some from as far as 85 miles away according to TVFOOL map and one from the other side of a 3000 ft mountain that is 5 miles away.
Everything I have read about digital signal indicates that I shouldn't be getting the reception I am getting, though I'm not complaining.
Here is my problem; Elements on the old antenna fold up every time the wind blows from the right direction so I need to replace it. My first thought would be to replace everything with new stuff and go with the strongest antenna possible but since I live on top of hill that's known for very strong winds for our area it seems like I should use an antenna or two that would take the least beating from the wind. Don't want to give up any channels either!
Sorry this got a little long!
Thanks,
76 Patton Farm Road
Stuarts Draft, Va. 24477
