Old 19-Jun-2012, 10:56 PM   #1
JTl
Sure could use some help
I am such a novice at this so please bear with me.
1. I can put an antenna either in the attic at about 10' or external at about 12'. Is the reception greatly influenced by inside or outside?
2. I cannot put an external antenna above the ridge of the roof (cannot be visable from the street). If I put it on the back of the house and point in the the direction of the towers the ridge is in the path.
3. I have quite a few trees in my neighborhood, but does it help to angle the antenna upwards vs being parallel with the ground?
4. My zip code is 34285, and antenna suggestions?
Thank you.
John
JTl is offline   Reply With Quote
