Thread: Confused
Old 2-Sep-2010, 9:56 PM   #12
acutshall
Originally Posted by Dave Loudin View Post
You're only a half-mile from one station (low-power, but still...) and pretty close to channel 10, so it is very likely any kind of amplifier will end up overloaded. A lower-gain antenna that covers high-VHF and UHF channels is the RCA ANT-751. You can mount this outside (avoiding up to 20 dB of loss through the walls) and run the cable to a 4-way splitter inside. You should have plenty of signal left for all the TVs, but now you know how to do the system design to be sure.
Thanks Dave. Cost is within reason too. So just point this towards the VHF (roof top level) and it should pick up channel 10 as well?
