Thanks Electron and ADTech. Based on your recommendation, I am going to use the C5 Antenna as is without Preamp on the roof. If things are not good then, I will come back. With the C5 on the ground at 3ft, I get all the Charlotte area channels without difficulty (with a CM3410 distribution amp).
If I need a second antenna to catch the Greensboro towers at 60miles, then I will go for DB4e.
Thanks everyone.
