Old 15-Jun-2012, 1:29 PM   #4
johncros
Originally Posted by Electron View Post
The mounting and antenna will be fine. Use strong sturdy screws.
Here are light weight aluminum lay over antenna towers. Do antenna mounting and adjustments standing on the ground. http://www.palcoelectronics.com
I thought about a tower for a little bit but my wife would never go for it I am trying the eaves mount because I did not want to go through the hassle of trying to secure a roof mount and penetrations with my cathedral ceiling. The mounting bracket comes with 1/4"x2" wood screws that I will be installing into hardiplank that I believe is backed by a 1"x4" board. I think they will be solid. Looking at most examples of chimney mounts and tripods, they seem to all use a larger separation. In your experience, have you encountered any general guidelines regarding antenna height and the separation between the mount points?
Thanks
Last edited by johncros; 15-Jun-2012 at 3:13 PM. Reason: fix spelling, complete comment
johncros is offline   Reply With Quote
