Old 14-Jun-2012, 7:33 PM   #21
Blackbeen
The DB4e reflector remains as-is. The suggestion regarding the C2 VHF kit involves using that kit for parts and mounting those key parts to the DB4e. It's a bit of a DIY "hack" or an "off-label" usage that brings modest VHF performance to the DB4e.
I still don't really see a need for an amplifier unless you are specifically trying to get Detroit stations.
One of the main reasons for chimney mounting IS to get Detroit stations, I ordered the C2 VHF kit & CPA-19 Preamp with the intent of running a separate coax for, I suppose if worst comes to worst I could run the power cable though the window edge with a flat cable to avoid boring another hole in the brick wall but I'll see what the installer suggests.
I hope that modest VHF performance is worth the 30 bucks, I thought the same money could have just about covered the cost of a decent separate VHF antenna but I didn't want to complicate matters with yet another separate cable run into my Apt + since I've installed the FM trap 11 & 13 (though not 100%) have been pretty stable even in the present position here as the UHF ones have been really problematic, even 30 which there absolutely is no excuse for.
Blackbeen is offline   Reply With Quote
