Thanks for the advice. You know the weird thing is that some of KATU AND KOIN were completely okay a few weeks back,now they are consistently bad. I don't know what happened. Also some intermittent channels like KWVT are watchable with a solid signal, some other times are completely cutting in and out. Especially when it's sunny.
Do you have any other smaller antenna suggestions? I'm pretty much surrounded by trees and that spot by the fence is the best/only spot. I can only raise the antenna about 10ft up too because of the trees. Maybe two antennas? Some channels I can pickup without an antenna.
