GUM is correct. There are only 6 stations in your area that need to be received: K25HS (KTVL-CBS), K15BP (KDRV-ABC), K14JB (KVMU-FOX), K44JB (KOBI-NBC) , K49HS (KSYS-PBS) and, if you want 3ABN, KBLN.
Everything else on your TVFool is either an unbuilt construction permit or a duplicate translator of stations you're already getting. You're not likely to get many (if any) of the translators from neighboring valleys. Even if you did, they'd be duplicates, so there's really no point in chasing them.
Only a UHF antenna is needed for Grant's Pass stations.
You've been basically chasing ghosts that don't exist.
