ALL questions and answers about Tv reception and more
WFUP 45 FOX is very weak at , minus -3.1 NM(dB) , I recommend the HD9095P but you can try the DB4e if you like.
Both the HD9095P and DB4e antennas are aimed inbetween the 2 groups of stations to the south at about 190 degree magnetic compass.
I recommend try reception without a preamp.
If a preamp is required for reception , then connect the CPA-19 to the output of the UVSJ so both antennas are amplified.
