Old 13-Jun-2012, 10:21 PM   #9
Electron
ALL questions and answers about Tv reception and more
Most likely a bad connection at or close to the antenna. If at any time water has gotten into the coax then replace the coax.
Or the coax has just gone bad , Replace to coax on the outside.
All so replace the matching transformer (balun) if one is connected.
Aim the antenna at about 327 degree magnetic compass.
For a new antenna install a HD7698P aimed at about 327 degree magnetic compass.
The HD7698P antenna is a large antenna and as such will receive the most Tv stations.
A amplifier will most likely not be required.
http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
Here are some STRONG and STURDY antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Buy the ronard mounts at solidsignal by typing the word ronard in the sloidsignal search box or buy from ronard.
