Old 12-Jun-2012, 6:52 PM   #7
sara
Originally Posted by Electron View Post
A simple reception situation. Install a Antennas Direct DB4e aimed at about 240 degree magnetic compass. And install a Antennas Direct C5 aimed at about 266 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/poinying/pointing.html. Install a Winegard Direst AP 8700 Preamp.
The C5 comes with a combiner the combines the DB4e and the C5 antennas.
The preamp is connected to the output of the combiner.
  1. Is there a particular reason for choosing DB4e over a C4? I want to color to be black to match the roof. Our neighbors and HOA are very picky.
  2. When you use a AntennasDirect VHF/UHF combiner does one lose all the UHF signals coming from a C5? Obviously the UHF stations pointed in the right direction of C5 will have better signals than a DB4e at an angle to the tower. Can you please explain what goes on in such situations?
  3. Is it more appropriate to use a TV antenna coupler? (e.g. Winegard CC-7870 2-Way TV Antenna Joiner Coupler)
sara is offline   Reply With Quote
